Originally Posted by Paul Bosslet
Hi,
I've read that the TPM valve stem batteries are supposed to last 7 years before replacement of the entire valve stem is necessary. The battery can not be simply replaced. If a TPM battery fails before 7 years, it is likely that you will not be able to get the TPM warning light to turn out even though all the tire pressures are correct. My system works okay so far but I understand that the TPM valve stems are pricey.
About $120 per stem on the TPMS sensors. Of course that can vary from vendor to vendor. SOWARDCUSTOMS quoted $101.60 on his thread with 20% off, if he is still doing that, it looks like he is. page 2 post #40
https://www.crossfireforum.org/forum...ad.php?t=29356
Was 25 degrees here this morning and mine came on, no surprise though, not when it drops this cold all of a sudden.
