Old Dec 23, 2008 | 09:08 AM
the.Santorini's Avatar
the.Santorini
Default Re: Clarion FB275BT SD-card head unit ordered
Originally Posted by victorczx3
about the radio , its not bad at all......unless you are picky! and demand full clarity from a 100$ unit.......but if your like me you will use the SD card almos 100% of the time. bluetooth also works great! i recomend to take the extra time and install the Mic that comes with it .....it made a big difference on my phone calls while in the car.
the scrolling part for music on the SD is a little tricky and you need time to adjust. once you learn how to switch from folder to folder in SD mode you can press the "back button " and the selector will drop down to the music of that folder then you can scroll by song with the **** insted of the "forward or back buttons" again unless you have tons and tons of music this may take a while . but remember that this unit does not handle "high capacity SD cards" so for now 2GB is the most I have been able to use.
hope this helps .
When you mention the quality for $100....I only have the stock Infinity receiver now. Disregarding the variations in MP3 sound quality, how would you compare the sound quality of the unit to the stock Infinity?
