Old Dec 27, 2008 | 03:24 PM
  #48 (permalink)
texas t's Avatar
texas t
Exclamation Re: DIY Performance Intake (Like Code 3's)
Originally Posted by tighed1
Sounds interesting!
How did you block off the factory inlets?
Did not seal off the the factory inlet tubes. Sealed up code 3 intake mode and now i am using the oem set up. I am going to disconnect 1 and or both of the oem inlet tubes an postion them where the aftermarket tubes and filter would be located,between rad and engine If this is going to be a cold air intake mod we need cold air. I am condersidering using a coolant type of device that the intake air will pass thur remove heat and reject to outside car. I am now trying to find out what temp would be best if it could be maintained within a specific range anyone know. Please chime in!
