DIY Performance Intake (Like Code 3's)
Old Nov 16, 2008 | 11:46 AM
  #41 (permalink)
tighed1's Avatar
Default Re: DIY Performance Intake (Like Code 3's)
Originally Posted by splinter
+1
Incidentally, did your 181mm get bolted to the crank this weekend?
you talkin to me?
Old Nov 28, 2008 | 09:16 PM
  #42 (permalink)
SRT6nTulsa's Avatar
Originally Posted by texas t
The material is 3 stage each stage to catch different size particales. Last stage not seen in photo is very tight woven',.nothing but air will get through. The other 2 stages have a tack applied to them to hold particales in place ,so not to top load last stage. May not look good but sounds great .
If you're going to the dragon again, I'd love to hear it.
Old Dec 25, 2008 | 04:05 PM
  #43 (permalink)
texas t's Avatar
Hey guy I did the diy code 3 cai about a month ago. Today i took some temp of air entering thur code 3 mod. With 65 degree odat at 60 mph crusing was reading 80 at c3 intake ,and 85 in oem intake hose. So i found when using the c3 diy mod the oem intake hoses are for the most part not being used to supply air to engine the c3 cancels out the oem. Sounds very good , But what effect on performance . Also when idling in traffic 64 0dat 186 at c3 and 119 at oem hose. Tomorrow i am going to seal c3 mod and take more readings . I bet that air entering sc will be very close to odat.
Old Dec 26, 2008 | 10:43 AM
  #44 (permalink)
sccasrt6's Avatar
Next thing would be to design a muscle-car-style cowl-induction hood or scoop to take advantage of the location of the air intake. Just don't make it look like one of those glass-hooded Mustangs!
Old Dec 26, 2008 | 11:21 AM
  #45 (permalink)
+fireamx's Avatar
And for all you NA Crossfire Drivers there's always this:
https://www.crossfireforum.org/galle...hp?photo=23862
Old Dec 26, 2008 | 02:57 PM
  #46 (permalink)
texas t's Avatar
Smile Re: DIY Performance Intake (Like Code 3's)
SEAled c3 diy intake mod, 80 degree odat at 60mph had 82 to 85 degree entering intake. It appeared that the slower the speed the higher the intake temp . I was also thinking if the intake tubes are bigger this would result in the oda to move slower thur piping and have more time to absorb heat generated in engine compartment specially at lower rpms and lower speeds. Now i am going to take temp between motor and radiator to see what goes on temp wise with cai located there.
Old Dec 27, 2008 | 01:55 PM
  #47 (permalink)
tighed1's Avatar
Sounds interesting!
How did you block off the factory inlets?
Old Dec 27, 2008 | 03:24 PM
  #48 (permalink)
texas t's Avatar
Exclamation Re: DIY Performance Intake (Like Code 3's)
Originally Posted by tighed1
Sounds interesting!
Did not seal off the the factory inlet tubes. Sealed up code 3 intake mode and now i am using the oem set up. I am going to disconnect 1 and or both of the oem inlet tubes an postion them where the aftermarket tubes and filter would be located,between rad and engine If this is going to be a cold air intake mod we need cold air. I am condersidering using a coolant type of device that the intake air will pass thur remove heat and reject to outside car. I am now trying to find out what temp would be best if it could be maintained within a specific range anyone know. Please chime in!
Old Jan 26, 2009 | 07:00 PM
  #49 (permalink)
Mr. Max's Avatar
I did a Tighed1/ Code3 (sounds like a score) variation. I was worried about the air cleaning efficacy of that little green Code3 foam filter. After seeing the Tighed1's DIY job I added a single sheet of hepa filter on the outside of the foam. I lost a little of the scream but it's worth it to know I'm not sucking huge amounts of earth into my pricey AMG engine. Now I only suck in a little lol.
Old Jan 27, 2009 | 01:40 AM
  #50 (permalink)
Forza1's Avatar
Can someone measure the distances of the screw holes?
Old Aug 22, 2015 | 03:33 PM
  #51 (permalink)
SeanOldaker's Avatar
Is that the best filter option? Is it safe? If it is i might end up doing this
Old Aug 30, 2015 | 01:50 PM
  #52 (permalink)
Mr. Max's Avatar
I use green foam (Code 3) right behind the supercharger. It filters well but has to be cleaned and oiled often. Actually I see bigger holes in my K&N filter but the K&N can go much longer between cleanings. As far as the Hepa filters, I would imagine the same thing, change them often. Look on the throttle body side to see if the dirt is getting through. If it is come up with plan B before you ruin your cylinders.
Old Aug 30, 2015 | 01:56 PM
  #53 (permalink)
Mr. Max's Avatar
P.S. The sound is awesome but you are sucking hot air. I use the Needswings type in the summer and the foam in the winter. It seems to have more grunt with the foam but maybe it just sounds faster.
Old Aug 30, 2015 | 08:48 PM
  #54 (permalink)
Has anyone done this cowl induction yet? Or run a pipe up to the hood seal and remove the seal?
Old Sep 13, 2015 | 12:47 PM
  #55 (permalink)
Dep281's Avatar
Question Re: DIY Performance Intake (Like Code 3's)
Did anyone just cut 2"- 3" of rubber out of the hood seal? Wouldn't this allow a little more air without too much weather getting in?
Old Sep 13, 2015 | 12:49 PM
  #56 (permalink)
Dep281's Avatar
PS just bought my srt6 and this is a first post so don't hammer me too hard for stating the obvious! LOL
xfireohio
Jul 20, 2020 12:03 AM
HOT FIYA
May 31, 2019 08:01 PM
Dec 2, 2015 12:49 AM
Ralph289
Aug 19, 2015 08:27 AM
Arm_and_a_Leg
Aug 14, 2015 12:25 PM
