Originally Posted by waldig
Typically about 14, same with or without the boost line hook up at Idle. See the D/L chart on the next post, Three wishes...
I have to try and do some more research to control the boost line to the fuel regulator. Iam looking at using a 02 sensor to drive the fuel pressure via the boost line signal. This would close the loop, allowing the fuel to be controlled AT WOT by the F/A signal, sota a goal at this point. Ill keep you posted, testing needed.
Woody Enjoy
Woody, my inbox is cleared. Sorry.
Your o2 sensor idea seems good, but how about simply running a manual boost controller?
