Re: anybody with alternator experience HELP!!!
what do I need to search for exactly? I tried finding the alternator at rock auto, and couldn't find the one mentioned above. And as far as install, just remove the tire, and you can access all bolts easily. I assume there is enough room to remove it from either direction? I still have the factory battery, sitting in the garage, but I didn't wan't to run two batteries. Thanks for the help so far on this matter. Any idea how much wire I would need to rerun the wires from battery to alternator, and engine to ground? If I'm going to get this envolved, I might as well finish the big three upgrade. thanks again chris
