Old Jan 20, 2009 | 10:43 PM
faiz23's Avatar
faiz23
Default High output alternator available upto 260 amp
hey guys did some digging around since i was curious about getting a high output alternator for the crossfire and wanted to see if we could crossreference a slk alternator or another mercedes alternator for use on our crossfires. I have not done much business with this company but in the aftermarket world for alterntors they are regarded highly. I am still confirming with them it will work for us an if it will work on all models. I believe all the alternators are same between the different crossfires. Here is my email between them and the ebay page.
http://cgi.ebay.com/ebaymotors/200-a...spagenameZWD1V
Re: You've received a question about your eBay item, 200 amp Iraggi Alternator (99-04) Mercedes‏
From: <img id="P___1694728340" webimdisplaystyle="inline" style="display: none;"> Dominick Iraggi (dominick@tds.net)
You may not know this sender.Mark as safe|Mark as unsafe Sent: Tue 1/20/09 11:56 AM To: faiz_23@hotmail.com
Here are all your options.
180 $399
200 $419
220 $439
240 $459
260 $479
Thanks,Dom
eBay Member: faiz_23 wrote:
Dear trafficjamz,
i have a 2008 chrysler crossfire and it is heavily based of the mercedes slk from 98-04. i want to look into getting a high output alternator and want to see if you will be able to supply one. the 2004-2007 crossfire alternator is compatible with
CHRYSLER CROSSFIRE 2004-2007 V6 3.2L
MERCEDES BENZ C230 2002 L4 2.3L
MERCEDES BENZ C240 2001-2002 V6 2.6L
MERCEDES BENZ C240 2003-2005 V6 2.6L Base Models only
MERCEDES BENZ C32 AMG 2002-2004 V6 3.2L
MERCEDES BENZ C320 2001-2003 V6 3.2L
MERCEDES BENZ C320 2004-2005 V6 3.2L Base Models only
MERCEDES BENZ CLK320 2003-2005 V6 3.2L
MERCEDES BENZ ML320 2002-2003 V6 3.2L
MERCEDES BENZ ML350 2003-2005 V6 3.7L
MERCEDES BENZ SLK320 2001-2004 V6 3.2L
not sure if the 2008 is the same i would like a high output option if not can you use the stock one and rewind it to increase the amp from 120.
- faiz_23
