Old Jan 24, 2009 | 09:06 AM
ppro's Avatar
ppro
Default Re: Which head units require no wiring harness?
Originally Posted by paul1612
Does this unit require an antenna adaptor or does everything just plug in?
The free downloadable Blaupunkt St Louis MP56 owners/install manual is located here:
http://akamaipix.crutchfield.com/Man...023STLMP56.PDF
According to Crutchfield, no installation kit is required to install this in a 2004 Crossfire with factory Infinity (Non-Navigation) stereo.
http://www.crutchfield.com/p_023STLM...6.html?tp=5684
http://www.crutchfield.com/S-nuKwNU4...archivedItem=Y
That suggests that it has euro antenna connection and already has the proper harness connector.
Here's the drawing from the Blaupunkt Owners/Install manual of the harness connection
Here's the Crossfire Socket Config
Use this legend for the colors
It looks like Connector A, Pins 1, 2, and 3 are not assigned the same
- Pins 2 and 3 appear swapped
- Pin 3 in the car is not installed (but available from Becker)
Bottom line - Since Pin 1 is unused on the radio, Pin 2 and 3 are unused on the car, these three pins don't matter - if you decide to install a handsfree and want mute function, or install a sub, you'd be dealing with these pins)
But the remaining A pins and B pins are a perfect match. It looks like "plug and play" - but your mileage may vary.
