Old Jan 25, 2009 | 05:48 PM
j-fire's Avatar
j-fire
Default wheel offset question
i am planning on installing a set of 20x10's in the rear with a 42mm offset. will this look right? or will they be shoved under the car and not clean and flush with the fender wells? anyone install a setup like this? will a 15mm spacer be sufficient enough to fix the problem? (assuming there is a problem)
thank-you so much in advance for your help!
