Old Jan 26, 2009 | 10:17 PM
Franc Rauscher
Default Re: When will the clutch die?
Originally Posted by Mr. Max
I used to wear them out way too often on my turbo Z. I finally bought a new clutch and took it to these guys in Irwindale (CA) and they put ceramic pads on both sides of the disc. Well, that was way to jerky. I went back to these guys after a while and they put ceramic on one side only. That was perfect and my clutch never slipped again. Just a little food for thought if you're replacing your clutch.
First, I love your new sig,
I put three clutches in my Olds Starfire in 30K miles. Had one special built from a Corvette assy and pressure plate. went over 200M using the same driver and often pulling a trailer.
Beefy clutches exist. As far as I know, the Crossfire has one. I would assume at least 100K.
Unless you are pulling a trailer.
roadster with a stick
