When will the clutch die?
I'm hoping that my careful driving will avoid problems. In other posts there is mention that Mercedes parts are cheaper than Chrysler. It's a matter of matching up the clutch pressure plate and throw-out bearing part numbers. But the quoted ~$650 for the pair sounds reasonable. For a high end labor estimate, it took 9 hours to replace the clutch and flywheel on my A6 quattro which I suspect is more difficult to access due to the quattro. Maybe someone has had a clutch replaced on a 3 series BMW which is also RWD.
I'm also wondering if AMG made any high performance (= stage 2 or 3) clutch plates for the SLK320. A heavy duty clutch should last forever in the n/a engine.
Originally Posted by 70GT6
Yeah $2500 is a bit much. (at least double of what is should be for a disc, plate, and bearing + install)
Now if you also replace the bearing there is another $300.
The list price for the pressure plate and disc is $583 - discounted to $422.29
If you need the the release bearing (always a good idea) list is $310 discount $223.85
http://www.quadratec.com/products/52161_100.htm
Originally Posted by Jeep2Xfire
You can just replace the friction plate. Plan on going back in very soon.
Replace the plate, the throwout bearing and resurface the pressure plate.
Dealers want $2,500 'cause they job some of this out and, it is a Benz, not a Chevy Cobalt.
You are not tossing a new set of brake pads in. I haven't been under there myself but; Split drive shaft has to be pulled, carrier bearing, Tranny down and out. Hydraulics capped off and then bled for reconnection.
Like I said, it ain't a Chevy.roadster with a stick
It was shifting just fine until I took the car to the body shop since a gate fell on the quarter panel. It wasn’t slipping until I got the car back, I should have took it back and told them but I didn’t. I could have easily drove that car around 10k but whoever at the body shop couldn’t drive the car to save them
Are you saying someone at the shop tore the clutch up, playing with the car? Cause it sounds that way to me. I don't see how a gate "falling on the quarter panel" could cause this.
franklindm
Mar 14, 2020 12:23 PM
crossfireusa
Oct 28, 2015 12:03 AM
unarel32
35
Oct 6, 2015 05:53 AM
bobbie
Sep 12, 2015 12:49 PM
