Originally Posted by drydock
Sorry about the late reply. I've been VERY busy building a new spaceship. So, the F-1s are now making noise. My daughter thinks the noise adds to the car's mystique. Oh well, great traction in the snow and that's real important out here in Broomfield.
I have a couple of questions for the Crossfire experts. I need to remove a door panel. Is this trickey? Instructions are poorly done in the manual. How do you remove those funny Mushroom head fasteners on the interior panels? Also, I need to add an audio cable to the OEM stereo (Infinity) so I can hook up my iPod. Has anyone done that?
Door panel removal 1 remove torque screws from Door handle (2) handle needs to be separated at seem. 1 screw to be removed from behind tweeter in door carefully pry out plastic surround. Remove screw from behind SRS plastic clip. Remove front triangle piece from top front of door and remove plastic latch cover and metal protector from back topside or door. Then starting at bottom rear corner slide hand up between panel and door and gently pull away from door slide hand along bottom toward's front lightly pulling.
