Old Feb 15, 2009 | 08:07 AM
  #288 (permalink)
mbepic's Avatar
mbepic
Cool Re: WOW ... stop the rust while you can ...
Yeah, I hear they had to put stronger rain seals on the UK models, what with all that weather you guys have over there.
Just kidding you, that looks like the lower seal, the one that goes along the bottom of the door. This discussion has been about the seal that goes all around the sides and the bottom of the doors. It is located above this seal.
The snaps on your seal should just pop back in if you have not broken them.
The correct seal, as onehundred80 explained, is larger diameter, roundish in shape and really pliable and I believe the side of the rubber that goes in the metal track is flatish shaped.
I believe you have removed some other seal along the outer edge of the door and hopefully you can reinstall without difficulty.
