Old Feb 17, 2009 | 05:26 AM
IMPERIAL4EVER's Avatar
IMPERIAL4EVER
Default Re: HeadLight's ON when parking turning engine off
I am afraid this is totally correct ,the daytime running lights as fitted to Canadian Xfires are exactly as in the book. There is no half power high beams as you say. You cannot select high beams until you switch the lights on. You can flash them but not put them on. You can legally drive at night with the DTR lights.
I'll let you know. This Sat the dealership will be programming the DRL on the Crossfire and they had to order a module to do so. I asked the dealership and they said only the main headlights will turn on. Boy will they be in for a surprise if all of the exterior lights go on.
