Old Feb 26, 2009 | 12:19 PM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Spring pad question
Originally Posted by Mad_Med05X
What is the stock size of the 05 Crossfire pads Front & Rear?
How hard is it to replace the pads while installing lowering springs?
Depends on the factory set up - I had the thickest pads in the back (17mm) and the second thinest in the front (9mm) but the pads are cheap - about $30 for a set of four
Easy to replace when you remove the springs.
If your lowering your Crossfire - dont forget to shave the bump pad (A) in the shocks.
