Supercooler / heat exchanger
Feb 28, 2009 | 11:11 AM
39
permalink
BrianBrave
<--- Huge Horsepower
Apr 2007
3,217
So Cal
- Forum Super Sponsor -
Re: Supercooler / heat exchanger
Quote:
NeedsWings
open valves, let ic and rad intermix, drive to flush all bubbles, close valves
What happens with this closed system if/when the coolant gets hot and needs to expands/surge? Say on a long run, or a hot day or should the IC pump fail?
IMO you'll to design in a
pressure relief valve. Same idea as a radiator cap or a water heater.
Without a surge tank for the coolant to expand into (or release pressure)........ You run a high risk of your intercooler bursting since it's nearest to the heat source and the weakest link and ingesting coolant into the engine.
My Dos Centavos
BrianBrave
View Public Profile
Send a private message to BrianBrave
Find all posts by BrianBrave
