Depends on the factory set up - I had the thickest pads in the back (17mm) and the second thinest in the front (9mm) but the pads are cheap - about $30 for a set of four
Easy to replace when you remove the springs.
If your lowering your Crossfire - dont forget to shave the bump pad (A) in the shocks.
What the hell is this? I've never heard about doing this!
Does this really have to be done?
Can you better explain what need to be done? And why?
SHAVE WHAT? How much?
