Old Mar 14, 2009 | 06:52 AM
LantanaTX's Avatar
LantanaTX
Default Re: C32 Brake upgrade
Originally Posted by velociabstract
I've been looking at big brake kits. The C32 brakes seem to be a bolt on but you would need aftermarket rims or a spacer to clear the calipers based on what I've read. I have NO first hand experience on the subject but this is my understanding.
Les
Our wheels should be fine. SLK guys on the the Benz forum stated that you need at least 17" wheels. I just checked and the C32 came stock with 17" wheels so this should fit no problem. I also have been researching the calipers and you can get them with either "Mercedes Benz" of "AMG" on them. I just depends which vehicle they came on. for example the CLK500 uses the same caliper but the car was not an AMG. The prices are very reasonable compared to a big brake kit from Brembo and others. you can find used calipers for $200-$300 double that for brand new. There are lots of choices for the rotors. I would use ceramic pads and Goodridge braided stainless lines.
