Originally Posted by texas t
Haha!
Originally Posted by Jeff Cobb
Are the subs producing any output?
You might have blown a fuse in the amp.
Yes, they are, just seems like not as much as before.
Originally Posted by ppro
Some head units have an option to turn on or off the sub channels. If power is lost to the head unit, the option might default to the "off" position. Did you disconnect your battery right before you started noticing this? The fuse sounds like another possibility.
My head unit does not have this type of setting, and I reset it to factory defaults in the hopes that I messed something up, but still no dice..
I'll maybe try checking out the amp today and see if I can find a blown fuse. Thanks for the insight!
