Sure you can! The SL55 V8 is very similar (bore and stroke, engine RPM, S/C PSI, etc...) to the 3.2L V6 with just 2 more cylinders.
It's not like trying to compare our V6 to a top fuel dragster? - Lol
Lol, they are 2 different engines, one is a V8 and one is a V6. They make different hp and torque numbers stock and you can not compare the 2 like that. It is apples to oranges. You would need to test the V8 with the stock intake and with a cai and then you would see if there was a gain or not.
You can not say 2 engines are the same just because they are from the same company and are the same displacement if one is a 6cyl and one is a 8cyl or if one makes more power than the other or if one is designed differently than the other lol.
