Old Mar 18, 2009 | 11:05 AM
amx1397
Default Re: got a new intake and
Originally Posted by mrphotoman
Have you ever thought about getting a CAI to help your times when you drag race? I bet that would really help you down there in FL.
I had- have Code 3 pully, tune, stock intake,,, 12.40,, R. has 181 pully,, same tune as i ,,and CAI,12.50 I think ,, we run the almost the same times,,, now i add the SL55 intake .. I also removed the plastic restricted boxes in the radiator support, the ends of the tubes from the SL55 were heated with a heat gun ( could use torch or hair dryer) and forced into the hole next to the radiator then a wet rag was forced into hot end of the tube ,,it is now the same configuration as the hole in the radiator support ((fits like a glove)) jim
