Thread: I need BIG help
Old Mar 24, 2009 | 07:14 AM
Stogey's Avatar
Stogey
Default Re: I need BIG help
I always try to use the KISS method of diagnosis ! Keep It Simple Stupid !
If you suspect a fuel filter, then change it out....they're cheap and you elliminate one suspect. Is the fuel cap tight ? Is it defective ? Have it tested.
A fuel pump would be a different story, you would need to take it to someone who is able to install a pressure gauge and read fuel pressure from the injector supply rail.
Point being, short of taking it somewhere and leaving it there are some things you can do without tying up the car indefinately.
Just my Dos Centavos
Good Luck !
