Originally Posted by cross><hair
Just noticed the maintenance sticker on my newly purchased roadster in the upper left portion of the windshield. It states it was changed with 5w30 rather than the reccomended 0w40. Please advise!
The comments are pretty much spot on here.
Here is a snippet from how stuff works:
The
viscosity grade (for example, 5W-30) tells you the oil's thickness, or viscosity. A thin oil has a lower number and flows more easily, while thick oils have a higher number and are more resistant to flow. Water has a very low viscosity -- it is thin and flows easily. Honey has a very high viscosity -- it is thick and gooey.
The net of all this is to stick with your oem requirements, however if you are a tad off with the 5w you will be fine for now but stay with the 0-40 as these cars were designed for the oil specified.
Thnx
Nate
