Will the wrong oil weight cause damage?
I buy 10-30w synthetic, it's the cheapest because that's what everyone consumes the most of trying to find 0-40 synth is almost impossible, and not neccessary for 70-90 degree climate.
Originally Posted by harbor
Why risk it if you're not sure whether it's got synthetic oil or regular oil, particularly if you just purchased the car?
Take it in or DIY with the correct oil & filter - You'll sleep better.
I always use the factory recommended 0w40, but 5w40 should be fine as long as you don't live in the North Pole.
Don't forget to consider the amount of sulfur and phosphates and different formulas. I considered using the 5W-40 Mobil 1, which has a significantly higher film strength- made possible by utilizing more of the sulfur compounds. The problem with this is these additional sulfur and phosphorus compounds make their way to the catalytic converters, which weren't designed for the excess "pollutants" which reduce the efficiency of the catalyst and you essentially kill your catalytic converters.
Wonder how many people have had to replace their cats because of this?
o55ie18
Oct 5, 2015 05:50 PM
