Old Mar 29, 2009 | 08:21 AM
drhrsh's Avatar
drhrsh
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
10.) Now insert your key and turn it to the right to the first click (position 1). Hold the key in this position and grab the black cylinder and rotate it counterclockwise about 90 degrees and the key tumblers will come out.
The steering lock assembly will now look like this. Next remove the electrical connector with two small wires (this is the key warning buzzer, the connector goes in either way). Then remove the parking interlock with the large black cable. This will require pinching the two black tabs at the rear of the connector.
11.) Now reach behind the assembly and you will feel the main electric harness connector. Pull and rock this toward the front of the car until it comes free.
