Old Mar 29, 2009 | 08:24 AM
drhrsh's Avatar
drhrsh
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
12.) Remove the screw to the right of the key hole to free up the upper panel. This will allow you to pry up the upper panel for access to remove the lock assembly.
13.) Next loosen the strap clamp with the 10mm bolt holding the assembly.
14.) Then locate the locking pin which is hidden under a trim piece next to the steering column. If you pry with a screwdriver and use a flash light you will see it. Push in the silver locking pin and rotate the assembly counterclockwise and pull it to the right and its out!
