Old Mar 29, 2009 | 08:31 AM
drhrsh's Avatar
drhrsh
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
17.) When reinserting the key and black cylinder the flat on the black cylinder needs to line up with the white nylon portion of the assembly. Then you can push it in and rotate it clockwise to lock it in place.
18.) Also when reinstalling the transponder ring the part where the wire comes out needs to line up with the flat spot on the black cylinder for it to pop into place.
19.) Don't forget to replace the one screw you removed from the top panel (I did!) before replacing the lower panels.
20.) The front upper edge of the lower panel snaps into place, then lift the back edge (toward the front of the car) and secure one screw to hold it in place. Then just button up the rest!
Again I want to thank Crossbow 39 for his help. I think it has accurately been determined in this forum that this assembly is the problem, not just the tumblers, or lubrication. The only problem I have now is the BAS ESP light is on. Apparently when the battery is disconnected it sets the light. If you refer to page 135 of your manual it tells you how to reset ( re synchronize it)
