Originally Posted by mrphotoman
Lol that is what I was starting to suspect as well!
It looks like this may be the issue:
That is definately shorter lugs than mine, the ones I have are.93" of threads. Where did you find them at, I even looked on the gorilla site and could only find lug bolt locks in that size. Do you have a part number?
That is a .008" difference, I guess mine are just barely enough to rub. The 3mm spacer I just ordered should do the trick, it will make my bolts .118" shorter or .812" long.
Thanks
It would be a LOT better just to cut down your lug bolts than to run spacers...............but that's just my opinion.
