Old Apr 18, 2009 | 05:39 PM
LantanaTX's Avatar
LantanaTX
Default Mercedes Brembo 4 piston calipers
Hello SRT folks, I was working on a big brake upgrade and ended up with something you all may be interested in. In case you haven't seen the C32 brake thread. While the C32 brakes are a bolt on swap, I ended up getting a great deal on similar calipers from a CL500 which reguired the use of 330mm SRT-6 rotors instead of the 345mm C32 rotors. So if any of you guys would prefer four piston Brembo calipers, they will bolt on with your stock rotors and will work great on your cars. See my last post on the C32 brake thread to see how it is done. These are the calipers your cars should have come with.
