Thread: Race 2
Old Apr 24, 2009 | 10:49 AM
Glockhit's Avatar
Glockhit
Default Re: Race 2
Originally Posted by Sean760
Manually shifting your auto stick is for fun but it will likely make you slower since your not going to hit your shift points exactly when the automatic would and you will likely shift a few rpms below and a few rpms above meaning your not going to be consistant. A guy running a 6 speed will have a higher time but he wont run that time every time and the auto will always be within a tenth of a second. Test it out though if you feel your times can be better shifting on your own.
Actually your right except.. In addition to the HP mods I also have a sprint booster. If your familiar with how these operate (plenty of info on this forum if you do a search) it would have been better to use "drive". When I reached 60mph let up on the gas and slam it.
With a sprint booster and the TVT flash settings this seems to work better. Putting the car in auto shift and starting off in first then flooring it worked with the sprint booster only in first gear. After that the computer took over the shifting. I know Rob over at NeedWings keeps his on autostick in 1st. Then he floors it and lets the car shift. Of course this is at the track and he has a beefed up SRT6 without a sprint booster installed. Many of the forum members have their own opinions about what the sprint booster does and doesn't do. In any case I don't want to debate the sprint booster. It is what it is. I didn't have the control to do anything when floored. Just sit back and look over at the other car and hope for the best. Although there was plenty of power left to continue to 140mph plus. I seriously doubt that he could have hit 140 or 150 plus mph. He was a good car length behind me when I hit 120mph.
