Originally Posted by caughtNthexfire06
I havn't done any modifications other than installed new door speakers. I put in a new amp and sub also but I don't see why that would affect that. I took my radio completely out to see if that stops the problem.
It is a matter of elimination. 1st..What have I changed/added electronically to my CF. 2nd..Did this happen before I installed an electronic component. 3rd..Is it intermittent or does it happen all the time. Probably a short in the new wiring. Or wired wrong. Crossed existing wires or knocked other wires loose. Re-trace everything you did if #2. You'll find it. If not you will definitely find the answer in this forum. This forum is the best source for CF info you'll find anywhere. Good luck.
