Old May 1, 2009 | 02:12 PM
James1549
Default Re: Whale spoiler gasket?
Yes the mounting plate takes place of the active wing. What about your manual wing switch, does it have a light flashing on it when you drive your car? The active wing will unbolt as a unit, then simply bolt the mounting plate in place. Remove your hatch trim panel on the inside and you can see it all. James
Originally Posted by scoutmstr
James1549
Is the mounting plate that you mention instead of the OEM wing?
The PO had a dealer do it. I don't want to use that dealer for anything else. Vehicle has been this way for about 3 yrs. As soon as I get it remounted I'll try to post a picture.
As to the alarm above 80 don't know haven't been there yet but will let you know on the picture post
