Old May 11, 2009 | 01:52 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: P0341 Camshaft postition sensor bad?
Camshaft sensors are a more common failure on the M112 engines. The symptoms you are saying are in line with a sensor failure. Usually if the crankshaft sensor is going out you will be driving and then it will just die. The sensor dies gradually.
