full cooling upgrade
May 15, 2009 | 04:14 AM
permalink
Rasim
May 2008
86
I have ordered Sl55 intake Needswings pulley 178mm and inmotion tune, but I have +40C temperature in our country in Summer so i need to cool down my IC system, I want to order and install
Intercooler Reservoir
Johnson CM30 Intercooler Pump
, and performance
Heat Exchanger
but do not want to change my IC to a one from code3 that cost
$ 1 299,00
kind of expensive, then code 3 do not suggest to install CM30 pump because of reason I do not understand what is he trying to mean by saying? “
</SPAN>
Most people upgrade there IC pump with a higher flowing Johnson pump when the OEM piece fails. Unfortunately, the stock IC can not handle the increased flow from the CM30, and thus backs up the inlet side of the IC, causing increased pressure and slower recovery cooling. Our new IC eliminates this bottleneck.”
Tell me please what is the problem to use higher performance pump with stock IC
Rasim
View Public Profile
Find all posts by Rasim
