full cooling upgrade
Old May 15, 2009 | 04:40 PM
Rasim's Avatar
Default Re: full Cooling upgrade
Originally Posted by slk32krazy!
heres a few specs on my car. 2002 slk32 amg. built 06 /02. im the 3rd owner. got the car with 36,000 and small change. upon an inspection at the vegas m/b dealer i/c was said to need replacement. flew out bought the car drove it home with no issues.
upon doing a full fluid swap i decided to swap the pump. futher inspection of the pump showed copper winding failure in 2 spots on the pump. the inside was completely covered in black soot.
i know have a little over 40k on the car with no i/c issues. a search thru mb world or benzworld will show most use the cm30 due to its longevity and superior flow. while this forum may be fairly new to the cm30 it is primarily a marine pump and well proven
if you search the c32 or r170 forums you will find many drivers swapping to the cm30. i cant speak for the stang or lightning guys. im sure most here are aware the slk32 and the srt6 are very similar with the exception of the body. frame driveline suspension brakes are all the same.
the major difference is i have the choice of a hardtop or a convertible!!
Now about separation engine radiator from IC HE do you mean I will need 2 pumps 1 for radiator and 1 for HE? If yes, so do I need to order cm30 pump or it will not need if I separate systems and then 2 bosh pumps will be ok ?
Old May 15, 2009 | 04:43 PM
32krazy!'s Avatar
no. you are simply rerouting the hoses so that the fluid from the radiator anf the fluid from the i/c do not mix. the pump only flows for the i/c. the waterpump on the motor flows for the radiator 1 pump is all that is needed
im not sure if you have seen these videos by waldig. it may help explain things https://www.crossfireforum.org/forum...taaa-daaa.html
Old May 15, 2009 | 04:57 PM
Rasim's Avatar
Slk32krazy i do not need guarantee answer for my car I just need a suggestion if there is a performance for that you have already answered that YEAS there is temp. drop and second that it is not a fact that if use cm30 pump then IC will definitely leak because of increased pressure, you told me that many people use and nothing happened that is all I need to know. So will go for it thank you
Old May 15, 2009 | 05:33 PM
32krazy!'s Avatar
Default Re: full cooling upgrade
i dont thinkn you will be dissapointed. if you can watch waldigs videos. they are very helpful
Old May 15, 2009 | 06:05 PM
BrianBrave's Avatar
<--- Huge Horsepower
Yes - you will see a 25*F - 35*F reduction in IC coolant temperature by isolating the the IC coolant from the Engine coolant system.
Here is a easy do-it-yourself post. It would be a little different for the C32 as you dont use the same factory surge tank. - but it should add reliability to the system. <LINK>
No - The CM30 pump will not harm your intercooler, or will it reduce your IC coolant temps that much - when no other changes to your system are made.
Old May 15, 2009 | 06:20 PM
Rasim's Avatar
now i understand how to separate, but do not you think that huge HE will interrupt air flow to on the engine radiator?
Old May 15, 2009 | 06:25 PM
32krazy!'s Avatar
its my understanding by going to a 170 or 180 degree thermostat and resetting the fans to come on 10 degrees sooner there anrent any issues with the supercooler. many srt6 owners have them and no issues have arisen
engine temps dont seem to be an issue with these engines. its the i/c temps that most worry about.
Old May 15, 2009 | 06:56 PM
Rasim's Avatar
All clear thanks, i saw diagrams i am not sure i can do your way to separete with ice, but i quess i can make diagram number 2 that i definitely understand how to do, now one last thing is where to find that HE for c32?
Old May 15, 2009 | 07:01 PM
32krazy!'s Avatar
let/eurocharged makes a h/e as does needswings. im not sure if the needswings will work email them to find out.
code 3 also makes a h/e but they are having some serious customer service issues, you may want to wait to see if they survive the fallout
by using the videos a custom unit can be made easily with some measurements and a competent welder
the h/e used by woody is summit racing part number sum380645
also the separation of the i/c and the engine fluids is not mandatory. with the new h/e and cm30 installed with the factory plumbing you will still see reduced temps
syfi
Mar 28, 2026 04:14 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Sep 28, 2015 07:40 PM
ozkancab
Sep 25, 2015 10:55 AM
