Old May 15, 2009 | 06:05 PM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: full Cooling upgrade
Originally Posted by Rasim
Slk32krazy i do not need guarantee answer for my car I just need a suggestion if there is a performance for that you have already answered that YEAS there is temp. drop and second that it is not a fact that if use cm30 pump then IC will definitely leak because of increased pressure, you told me that many people use and nothing happened that is all I need to know. So will go for it thank you
Yes - you will see a 25*F - 35*F reduction in IC coolant temperature by isolating the the IC coolant from the Engine coolant system.
Here is a easy do-it-yourself post. It would be a little different for the C32 as you dont use the same factory surge tank. - but it should add reliability to the system. <LINK>
No - The CM30 pump will not harm your intercooler, or will it reduce your IC coolant temps that much - when no other changes to your system are made.
