Old May 15, 2009 | 04:43 PM
32krazy!'s Avatar
32krazy!
Default Re: full Cooling upgrade
no. you are simply rerouting the hoses so that the fluid from the radiator anf the fluid from the i/c do not mix. the pump only flows for the i/c. the waterpump on the motor flows for the radiator 1 pump is all that is needed
im not sure if you have seen these videos by waldig. it may help explain things https://www.crossfireforum.org/forum...taaa-daaa.html
