Old May 15, 2009 | 09:06 AM
Rasim's Avatar
Rasim
Default Re: full Cooling upgrade
Originally Posted by slk32krazy!
english aside do you understand now that the pump has not been proven to be the cause of the i/c leaks?
it has however been proven to be more reliable than the stock bosch pump
Oou now i think i ungerstand, so Code 3 say that if i install Cm30 pump and not upgrade IC to a bigger one that has been selling for 1299$ the stock ic will not able to handle increased flow and IC will LEAK. that is bull crap as you think.
So you say there is a point to install cm30 pump with a stock ic and everything will work more than normally and there will be a gain to my cooling system, is that what you mean?
