Old May 15, 2009 | 03:00 PM
ACRucrazy's Avatar
ACRucrazy
Default Re: full Cooling upgrade
Originally Posted by tom2112
Crazy: are you sure you need a separate resevoir for the heat exchanger? The IC should never get so hot that it would need an overflow, unlike the engine. So if you separate them, you shouldn't need IC/HE overflow.
The NeedsWings supercooler is designed with that in mind. Tonight will be its first night at the track. I'm hoping that there isn't much turn out tonight so I can get some back-to-back runs and really test this new supercooler out.
I dont want it neccesarily as a overflow, but more as added capacity tank that can have ice added to it.
I was thinking needswings, however if one can be bought from Summit for half the price with a little work to be used, I may go that route. I guess we will see how ambitious i get.
Right now the car is sitting idle for the next week or so while I claybar/polish the car, repair the foglights, change the brakes and plugs. The car is getting a full detail and Id like to get the cooling system out of the way.
