Re: New 4 post lift
Windward - couple of questions as I am planning on a lift in the near future (and probably from Greg Smith-Indy as well):
1) Did you buy one of the Pro Park models (made by DirectLift)?
2) I think you said it went together fairly easy - any lessons learned during the install?
3) Anything in retrospect you would do differently or things you suggest I double check or look at more closely?
4) The tech manual for the Pro Park says 8000lbs at a minimum 100" wheelbase - the Crossfire is obviously shorter than that - and obviously weighs around 3200# - any issues with this or did you discuss it with anyone at Greg Smith (I assume not)?
Thanks.
