New 4 post lift
Windward - couple of questions as I am planning on a lift in the near future (and probably from Greg Smith-Indy as well):
1) Did you buy one of the Pro Park models (made by DirectLift)?
2) I think you said it went together fairly easy - any lessons learned during the install?
3) Anything in retrospect you would do differently or things you suggest I double check or look at more closely?
4) The tech manual for the Pro Park says 8000lbs at a minimum 100" wheelbase - the Crossfire is obviously shorter than that - and obviously weighs around 3200# - any issues with this or did you discuss it with anyone at Greg Smith (I assume not)?
Thanks.
Thanks.
Thanks.
Thanks.
2. There were a lot of drill shavings around all of the pulleys so I took them apart and cleaned them while I was assembling the lift. Took extra time. I cut down the end stop plates so if I pulled on too far the front air dam on the X Fire or Vette would not hit the wheel stops before the wheels did.
3. Can not think of anything.
4. I assume that is a maximum. With my vehicles weighing less than half the capacity I do not worry about the loading. The platform does not bend any with either the X Fire or Vette. The lift does not struggle at all to lift them.
I had the lift delivered. It saved the sales tax since I live in Ohio. The cylinder seals are starting to leak. They sent a new cylinder packing but I have not attempted to install it yet. Only leaks when lift is all the way up. Comes out of the vent. The oil is getting past the piston and getting on the empty side of the cylinder since these are single acting cylinders. Just comes out of the vent. A little discouraging.
Hope that helps.
Brent
Originally Posted by Windward
... The cylinder seals are starting to leak. They sent a new cylinder packing but I have not attempted to install it yet. Only leaks when lift is all the way up. Comes out of the vent. The oil is getting past the piston and getting on the empty side of the cylinder since these are single acting cylinders. Just comes out of the vent. A little discouraging...
Originally Posted by Bat
Bladecutter and I are seriously considering a lift for our garage. Was wondering if you had any theories on what is causing the cylinders to leak (bad quality parts or just luck of the draw)? Approximately six months of usage is pretty short time for seals to start leaking.
Sorry for the late reply, I am on the road for work.
xfireon20z
Sep 10, 2015 04:27 PM
