Thread: New 4 post lift
Old May 27, 2009 | 12:00 AM
Windward's Avatar
Windward
Default Re: New 4 post lift
Originally Posted by Bat
Bladecutter and I are seriously considering a lift for our garage. Was wondering if you had any theories on what is causing the cylinders to leak (bad quality parts or just luck of the draw)? Approximately six months of usage is pretty short time for seals to start leaking. I can definitely understand your discouragement and would appreciate hearing whether the new cylinder packing/seals solves the problem for you.
I have not taken it apart yet but the other times I have found a issue like this the piston seal was cut during assembly. I hope the cylinder bore is smooth and good. These lifts are built in China so I guess you get what you pay for.
Sorry for the late reply, I am on the road for work.
