Thread: New 4 post lift
Old May 25, 2009 | 11:53 PM
Bat's Avatar
Bat
Default Re: New 4 post lift
Originally Posted by Windward
... The cylinder seals are starting to leak. They sent a new cylinder packing but I have not attempted to install it yet. Only leaks when lift is all the way up. Comes out of the vent. The oil is getting past the piston and getting on the empty side of the cylinder since these are single acting cylinders. Just comes out of the vent. A little discouraging...
Bladecutter and I are seriously considering a lift for our garage. Was wondering if you had any theories on what is causing the cylinders to leak (bad quality parts or just luck of the draw)? Approximately six months of usage is pretty short time for seals to start leaking. I can definitely understand your discouragement and would appreciate hearing whether the new cylinder packing/seals solves the problem for you.
