Hi Bluecoupe
No worries with resealing as i only used a very thin blade (2mm) to open them up to start with , you do not lose any depth so they fit right back together , just make sure you use enought sticky stuff to cover minimum 5mm each side of the cut line , its all under the rubber surround anyway ,so not seen
Cheers All
Andy
