Originally Posted by cgocifer
That's just about what I did, except that I used a four-point lift. I was going to take pictures, but i got so caught up in the work, that I forgot.
Excellent thread!
Hey, just curious, did your rear springs have clear rubber wraps around the coils on one end? Mine did.
Also, ever since the install, I've had an annoying, little, muffled thumpety thump in the rear when going over small bumps at speed. I've had the car up on the lift 3 times to check torques and to re-do the tightening process. I have no idea what it is, but it sounds like it is coming from both sides. Anything going on in the back of your car now?
Thanks!
Did you ever figure this out, mine is doing it too. The thing is I didn't have time to put the rears in, I started but was having problems getting the bolt for the control arm loose. So I put it back together and I'm getting a thunk, like something is loose, sound really bad. The only thing I didn't do is put the plastic covers back on.
