Originally Posted by rcompart
What are you using the relays for? If it's a 50A fuse that you're tying into, your 30A relay isn't large enough to handle that load. It might not always be that high but they put that size fuse there for a reason and if they could have gotten away with a 30A, they would have.
Right now I have a 50A rated toggle connected to the Hydraulic Unit(Traction) wire, I guess what I'm asking is do I need a relay at all or is the 50A toggle enough by itself?
Also, I have an identical 50A toggle for the yaw but I'm not sure what the amps would be on the yaw sensor so I don't know if I even need a relay for that either or if I do, what size it would have to be.
