Old Jun 13, 2009 | 10:38 AM
onehundred80
Default Re: Oil Pressure Too High ?
Originally Posted by BlueStorm
correct me if I'm wrong but this engine is suppose to have high oil pressure at idle. I remember reading something like 120-130 psi. someone can post the specs from the online manual.
one reason for the higher pressure is because of all the special piston oil spray tubes in series, talk about pressure loss. this helps remove heat from the pistons, also I'v yet to pull the pan but ther may be a windage tray keeping the oil in the case away from the crank, so you need to keep the alluminum cylinders lubricated or els you'll have a bad day, this isn't a cast iron motor. those cyclinders are coated with a very thin layer of carbide or something. you need lots of luberication, to all parts of the motor, hence the higher pressure to feed all the oil ports
DIAGNOSIS AND TESTING - CHECKING ENGINE OIL PRESSURE
1. Remove the oil pressure testing plug (1) at the base of the oil filter housing.
2. Install oil pressure test gauge assembly.
3. Start the engine and monitor the gauge readings CAUTION: If oil pressure is 0 at idle, Do Not Run engine at 3000 RPM.
4. Oil pressure (engine at operating temperature): Curb Idle 34.5 kPa (5 psi) minimum 3000 RPM 300–724 kPa(45–105 psi.
5. If the oil pressure is 0 psi at idle, shut the off engine and check the pressure relief valve; it may be stuck open or have a clogged oil pickup screen.
6. Install the oil pressure test plug and tighten to 10 N·m (89 in. lbs.) after testing is completed.
