How to polish your Socket to another Woody Idea for your Crossfire
Jun 17, 2009 | 06:52 PM
permalink
waldig
Feb 2008
4,508
34
VA
I have been doing some work on the car to gain control and traction by adding 8.5" x 18 wheels. Doing the work got me to thinking that I had another Trick that I could share with the crowd.
With 4 set of wheels and tires, I do lots of changing and have come across several hints to avoid the KINKS.
I use an impact socket but have polished it so that the end is SMOOOOTH. Its easy to do and takes only 2 minutes to do. I chuck up the socket in the impact and using a piece of 350 (or so ) wet or dry paper sand the end.
Using a glove, palm the sand paper and run the impact to spin the socket on the cup of your hand buffing the socket and end. THis takes a little bit of effort and will make the socket really shiny on the end.
The smooth and rounded end will not MAR the finish on wheels if you bump the surface while working. Chrome sockets arnt to be used with an impact and will not sand well due to the hardness of the chrome finish.
There are a few photos included as eye candy to show what it looks like. If your using spacers like Iam, then the use of 2 wheel starter bolts is recommended.
I first started posting on the forum with the starter bolts idea. THey are just bolts with the heads ground off to allow you to hang the wheel.
Hope the ideas assist your projects, Woody
waldig
View Public Profile
Send a private message to waldig
Find all posts by waldig
