Old Jun 22, 2009 | 08:33 PM
bombsquad56's Avatar
bombsquad56
Default Re: El Cheapo Heat Exchanger on my SRT6
Originally Posted by mrphotoman
Good price.
could you have flipped it so the inlet/outlet was on the other side to keep you from
having to run the hose to the drivers side?
There is a drain plug that sticks out about 3/4 inch. It would have poked into the radiator if I flipped it around. Plus this way I can have access to drain it. It actually has a threaded temp. sending unit fitting also on that side.
