Re: baddd dayyy
Well hopefully it isn't totaled, from what it seems I don't think you bent the frame which is honestly what totals these cars..framework lends itself to high repair bills.
If I were to guess in the rear tire you may have broken a tie rod loose..either broke it or just jarred it loose (but i suspect if that is it, it's broken)
As for the front, a good body shop should be able to pull the panel and re-align it...not sure what that would cost.
Good luck with your repairs
